Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on OSX operating system (including and above 10.8).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
1. For Textures attribute power defaults to 1.0 now. (see viewtopic.php?f=111&t=53049)
2. Default pass names for composite EXR are set when the respective field in render settings is left empty. (see viewtopic.php?f=28&t=53067)
3. Suffix _passes (and for non composite EXR all seperate pass names _****) is/are added before the framenumber. (see viewtopic.php?f=110&t=53046)
Installation:
DOWNLOAD
OctaneRender for Maya - v7.23 OSX
OctaneRender for Maya - v7.23 OSX DEMO
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
