Bug with standard max camera
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
mark0spasic
I found bug when using standard 3dsmax free camera. When I render image using octane render viewport and try to save image 3dsmax won`t open max framebuffer. This only happens with standard camera not with octane camera or when in perspective view. OctaneRender® for 3ds max® v2.25 - 2.17 3dsmax 2014.
This happens in any scene even in empty scene.
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
azen
Just to clarify - have you ever encountered this issue in previous versions of the plugin? If this has not been an issue in in 2.16 or before, this will make the issue far easier to isolate and resolve.
Cheers!
mark0spasic
Previously I had installed OctaneRender® for 3ds max® v2.25 - 2.15 and didn`t have any problems, this only occurs in v2.25 - 2.17.
azen
Thank you for the clarification. Version 2.18 has just been released, so I would recommend upgrading to that and seeing if that fixes your issue. I will confirm on my end if the bug can be duplicated in the new release - if the problem is still there, I will raise the issue.
Azen
mark0spasic
Hi, with new version everything works as is should v2.25 - 2.19. :)
azen
Excellent! Good to see that your issue was among those fixed in the recent releases.
Azen
Return to “Bug Reports”
