Hi!
Does anyone knows how to light the curtains under AO kernel?
As shown in the pictures below, the material settings of curtain material is ok for PT kernel... So I was wondering if it is also possible in AO kernel...
That you
L.
Curtain
Hi Lucio,
how is made the curtain material?
Do you have a diffuse material with transmission or with emission or with both or what else?
Ciao Beppe!
As you know, I have only transmission channel... in which I put, as always, some texture depending on curtain's material, as canvas, lace and so on...
Now, because of the good output of AO kernel, I'm a little bit upset for the 'glow' I can't reach as well as PT kernel (of course)...
That's why I wrote this post... Maybe someone has the solution, that I know isn't perfect but better than mine, for AO kernel.
I'll call you later.
Hug you
L.
Hug you
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
Hi Lucio,
since DL AO doesn't have GI, is difficult to obtain the same result than PT.
You could try to fake it by adding a slightly emission node to the curtain or a much powerful one to the glass in order to have more burning effect from the window
Another solution could be to add a scattering medium node if the curtain has a volume
