Default Camera on Octane
Vancliff2015
The first time I used Octane there was a camera set by default but I didnt take notice of which one. Now the renders are washed out and I would like to comeback to the default camera preset for Octane. Is there a way to do it, to reset Octane to its default state? Or could you indicate me which one of the camera preset is the default one?
Hi Vancliff2015,
the default response curve should be Agfacolor HDC 100 plusCD with Gamma at 1. If your renders are washed out, you have to correct your Gamma value, in general, there are two kind of curves, with Gamma 1 and with Gamma 2.2. Start from this values and slightly change them untill find your desired contrast.
For a neutral response, try with Linear and Gamma 2.2 ;)
