OctaneRender® for Maya® 2.24.2 - 7.22 Win [OBSOLETE]
k.a.schubert
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • 1. Attribute editor working again.
DOWNLOAD
OctaneRender for Maya 2.24.2 - 7.22
OctaneRender for Maya 2.24.2 - 7.22 Demo
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
calus
Thanks for the quick fix.
Pascal ANDRE
k.a.schubert
calus wrote:Thanks for the quick fix.
You're welcome! :)
Jolbertoquini
Hi Guys...
Just have to say excellent work for Render passes...UI :) We are really happy :)
Thanks a lot.
Jolberto
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
itsallgoode9
Jolbertoquini wrote:Hi Guys...
Thanks a lot.
Jolberto
can you post a pic of this? I can't update to a newer version than i'm already on for a good while and I was pretty unhappy with how it was implemented before. I'm super curious!
Jolbertoquini
Thanks a lot.
Jolberto
Yes of course take a look, this is just perfect. (from our side) :D
k.a.schubert
Thanks a lot.
Jolberto
Great to hear I could make your work easier right from the start! :)
kommando_2k
Request: Region Render I've been waiting for too long but 3.0 is nearly. Its very important for my work.
k.a.schubert
kommando_2k wrote:Request: Region Render I've been waiting for too long but 3.0 is nearly. Its very important for my work.
Region Render is working, its just a bit tricky.
You need to make sure that the camera you are rendering has the option "Use Pick Focus Region" disabled,
else Maya focuses the camera and does not render the region.
The option is here:
and then render region works as expected:
Hope that helps :)
Refracty
Welcome on board K.A. Schubert.
One question regarding ORBX.
When will it be possible to import ORBX objects?
