Team Render Setup OSX
muchogrande
Hi, I've asked this before and feel bad for asking again - but I can't remember how to get the Octane Plugin installed in a Team Render Client.
I need to place Octane.dat somewhere that the Team Render Client can find, but where? Using R17.
thanks!
It should be in team render client's preferences directory. Are you running the client without gui? I think i added a support to give licences throught prefs window in clients.
muchogrande
Ok thanks, I did not copy the plugin folder from C4D into the client's plugin folder. A very obvious mistake! After doing that the Octane username/pw appear in the client GUI and all is well.
Thanks Aoktar.
remeus
@aoktar can you please send the link which you added for solution?
aoktar wrote:It should be in team render client's preferences directory. Are you running the client without gui? I think i added a support to give licences throught prefs window in clients.
remeus wrote:@aoktar can you please send the link which you added for solution?
It's available in current and recent versions since a long time.
