OctaneRender® for Maya® 2.24.2 - 7.21 Win [OBSOLETE]
k.a.schubert
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • 1. The Render passes section in the OctaneRender Settings is now structured the same as in the standalone version as pointed out by Jolbertoquini.
DOWNLOAD
OctaneRender for Maya 2.24.2 - 7.21 (12.5MB autoinstaller file)
OctaneRender for Maya 2.24.2 - 7.21 Demo (11.7MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
zboog
A few things:
1) Since this update I can't seem to apply textures to materials without getting an error "// Error: Line 1.18: Syntax error"
2) EXRs don't output any of the channels unless I manually write in the name for each channel I want to include, even though the popup help text says "Leave empty for default value"
3) Render layer ID, Object ID and Light pass ID don't seem to work - they all just render a single color matte over everything (as opposed to different colors for different render layers, objects, or light passes)
calus
I can confirm these 3 bugs in maya 2016 sp5.
Also for the first one, the error happen as soon as you try to change any parameter of an octane shader in the attribute editor:
// Error: AEadjustColorTexValue \MayaWindow|MainAttributeEditorLayout|formLayout2|AEmenuBarLayout|AErootLayout|AEStackLayout|AErootLayoutP€ //
// Error: Line 1.23: Syntax error //
or if I try to add a node, in the attribute editor, this error:
// Error: AEattrNodeEditor \octaneDiffuseMaterial1.Diffuse\1; //
// Error: Line 1.18: Syntax error //
I can still add nodes in the node editor.
Pascal ANDRE
itsallgoode9
zboog wrote:A few things:
As far as I could tell, these were broken in earlier versions. I brought made a post about it but it never got fixed for some reason. that's a pretty major feature to be broken for such a long time. hopefully they'll fix it in on of these newer updates.
zboog
Speaking of things broken for a long time - what's the deal with Octane "Render layers"? You know, the thing at the way bottom of the OctaneRender Settings tab.
It would really be ideal to render all these render layers at once and have them split out into passes in an EXR file? Why would I want to batch render just one of these at a time (how it works now)?
k.a.schubert
See my howtos here:
Render layer IDs:
viewtopic.php?f=28&t=53027
Render light Pass IDs:
viewtopic.php?f=28&t=53028
Hope that makes it more clear. :)
Looking into ObjectIDs now.
