Copying Materials from Live DB
Moderator: BK
morphious2013
In Poser Plug you can right click a material and select keep existing maps, how is this done in Daz Plug?? Applying just an SSS material from Live DB.
If you load a LiveDb material in Poser, you cannot retain the existing texturemaps - the plugin will replace the entire material with the LiveDb material. The DAZStudio plugin works in a similar fashion - rightclick LiveDb material "Copy as new material", then drag it from Unused onto the Octane material you want it loaded into.
Return to “DAZ Studio”
