Octane LiveDB Texturemap Errors
Coulter
I'm frequently getting the following errors:
OctaneRender 2.25 (2250000)
Could not load 'B:\Coulter\Documents\Custom Content\Octane LiveDb Texturemaps:rgba'.
I double checked my file path under Preferences -> Octane and everything is correct.
i7 5930K Haswell-E 6-Core OC 4.2GHz // 3x GTX 980 Hybrids // 64GB RAM // Windows 10
It looks like the actual filename is missing (ie. it trying to load a texturemap with a folder name, not a full file path name). Which LiveDb material do you get this with pls? Which version of the plugin are you using?
Return to “Foundry Modo”
