lack of Marshner and anisotropy
aemelyanov
Hello, i'm new to octane but already found it's material system very capable for huge variety of looks.
but two things are frustraing me
- lack of anisotropy on speculars. Yeah, I tried to gain this effect with bump maps but it don't even close to things I could do in any other renderer with GGX speculars (renderman/mantra for example) in terms of desired result and time spent for setup.
- lack of separate hair shader - I use marschner for many years in prman (as in old one, as in their new RIS pathtracer) and it gives most realistic hair shading. i couldn't anyhow repeat this effect with glossy material, because I can't shift speculars in UV space. Do you have any plans to implement this?
thanks
Goldorak
OSL is intended to open the door to custom BRFD models such as GGX. We are in the process of validating this specific case as we continue to work on OSL support in 3.x.
aemelyanov
sounds great!
thanks
fantome
Hi guys sorry to ressurect this old post , but i would also be curious to know how would you proceed to build a great hair shader,
that has a look close to the marshner model ?
https://www.cs.cornell.edu/~srm/publica ... 3-hair.pdf
i have search inside the liveDB and i haven't find any good starting exemple.
i guess it all start with a glossy + anisotropic model, but do you have any tips or idea to make something really cool ?
This post is interesting but it doesn't deal with nice anisotropic spec
viewtopic.php?f=30&t=60853
Thanks for your lights !
Cheers
E
