OctaneRender® for Maya® 2.24.2 - 7.20 Linux [OBSOLETE]
Locked
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Implemented two different animated ORBX export modes:
    1. As a clean ORBX (the mode available previously). All geometry nodes will be accessible in standalone node editor after export. No vertex animation is exported (ORBX does not support vertex animation).
    2. Scene will be packed into Alembic node and exported inside ORBX. The vertex animation will be exported (using Alembic). No geometry nodes are visible/accessible in standalone node editor.
Installation:
DOWNLOAD
OctaneRender for Maya - v7.20 Linux (19.5MB autoinstaller file)
OctaneRender for Maya - v7.20 Linux DEMO (18.7MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
As promised we got a new developer here to be dedicated to Maya plugin. This must speed up the Maya plugin development, 'cause I've been loaded by a lot of different projects and Maya development has slowed down as a consequence...
So, please meet k.a.schubert. ;)
Please don't expect the immediate development speed up, because k.a.schubert needs some time to dig into a plugin...
Locked
