OctaneRender® for Maya® 2.24.2 - 7.19 OSX [OBSOLETE]
Locked
The OSX version of OctaneRender™ for Maya® plugin, 64-bit.
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on OSX operating system (including and above 10.8).
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Fixed the "ncam" command line flag.
  • Added the EXR-resolution setting to Octane "Additional" tab (16-bit or 32-bit).
  • Added "Passes EXR channel names" tab to Octane settings. Needed to fine-tune for some applications expecting specific channel names in EXR for specific passes.
  • Added "Ignore frame sequence bounds" to motion blur settings. If set - the full frames span will not be required for each motion-blurred frame.
  • Fixed alembic export bug.
  • Fixed "Before" internal motion blur mode bug.
  • Minor fixes and improvements...
Installation:
DOWNLOAD
OctaneRender for Maya - v7.19 OSX (18.0MB autoinstaller file)
OctaneRender for Maya - v7.19 OSX DEMO (17.2MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
As promised we got a new developer here to be dedicated to Maya plugin. This must speed up the Maya plugin development, 'cause I've been loaded by a lot of different projects and Maya development has slowed down as a consequence...
So, please meet k.a.schubert. ;)
Please don't expect the immediate development speed up, because k.a.schubert needs some time to dig into a plugin...
Next version HERE.
Locked
