visibility problem
HHbomb
We can use for some times visibility ( object properties / rendering control ) in octane render.
But it seems that even if an object is set to 0, it continue to be rendered.
I tried Rayfire with transparent objects and it don't work : all objects contribute to render.
I join a picture : two identical boxes : one set to visibility 1, one set to 0, and I move down the invisible box.... strange...
We need to have invisible objects to be invisible.... no contribution to rendering !!!!
coilbook
enable alpha shadows or uncheck renderable in object properties
i wish otoy can create Alpha shadows per object and not as a global feature. alpha shadows slows down everything a lot
HHbomb
renderable option is not animatable....
Return to “Autodesk 3Ds Max”
