csv rhino export
v-cube
Hello, I already posted this in the rhino forum but I think maybe you guys can also help me :-)
I would like to export a number of existing points from rhino as csv file and then reuse it as a scatter csv file to distribute objects in octane.
Unfortunately I was unable to export the points with the correct syntax using the normal csv format option, octane csv files must contain 12 values in this format:
https://docs.otoy.com/Standalone_2_0/?page_id=4951
is there a way to do this in RHino?
thank you for any feedback
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
v-cube
Paul ? :(
help !
Hi Andreas
There is a Rhino plugin which will do this for you (I think Newske wrote it?). Check out viewtopic.php?f=41&t=45376
Return to “Rhinoceros 3D”
