Specular Materials
Sub forum for help and tutorials.
zinogino
Hey guys, sorry if this was asked before cause I couldn't find it. Apparently I'm currently working on an animation for my client where he wants the scene to be glass like materials. My workstation is struggling with the performance of using specular maps in Octane(GTX880M single graphic card). Any other alternative to achieve something similar to specular maps or improving the speed performance when rendering mesh with specular maps?
Hi zinogino,
it's not easy to say without seeing an example image, but I guess that if you need to have the refraction effect, there is not so much that you can do beside reducing all the settings at minimum :roll:
if the refraction effect is not crucial, but it's more about transparency and reflections, than you can use the fake architectural glass by using a falloff node in the opacity pin of a glossy material ;)
zinogino
bepeg4d wrote:Hi zinogino,
Thanks for the reply, that's what I needed !
zinogino
Hi, was middle of rendering and I've notice some weird stuff on my meshes. In the LV it was alright.
Hi zinogino,
I guess that you need to check your mesh :roll:
Different subdivision in preview and render?
What about if you reduce the Phong value?
zinogino
There's no n-gons, alright.
Ibycus
Also make sure everything is connected by running the optimize function.
Return to “Help / Tutorials”
