Octane shader & X-Particals - only renders white
A forum for discussion, development and support, including subforums for discussion for various plugins for octane render and 3d the relevant animation packages
johnhill
Do you need to render geometry (polygons) when using Octane with X-Particlas.
Octane will render white particles using just the particles (no geometry), but Octane shaders do not seem to work when applied direct to the emitter. I though one can use octane shaders with just the X-Partical emitter without having to generate geometry? I'm using latest Octane version with C4D.
alecmaassen
bump, having the same exact issue right now.
alecmaassen
hey just found this. download these it will explain everything!
viewtopic.php?f=87&t=53297&p=268480&hil ... te#p268480
welcome!
Return to “Plugin Discussion/Support”
