Octane 3.0 Alpha4 Polygon Limit Issue?
jang2235
viewtopic.php?f=36&t=52672
Is it my own?
Titan X 3GPU System
Hi jang2235,
what are your system specs?
How much RAM do you have?
I guess you need a lot of system RAM to prepare 40M polys for GPUs :roll:
jang2235
My system
4790K 32G Ram Titan X 3GPU And 5930K 64G Titan X 1GPU And 3930K 32G Titan X 1GPU
System memory is not to exceed 24GB.
Hi jang2235,
please, could you share the scene via pm or via mail to help at otoy dot com?
jang2235
Especially not just what it sets.
I just started to know the maximum polygon Titan X.
I saw an architecture design was intended Tirangle want to find out the maximum when using Octane3.0 and TitanX.
So the results started to import polygon meaningless without the Texture and Material.
Lightwave is a user error and to have the same result also tested Octane Main program.
Octane Plugin Developer and OctaneRender Team also contact the state you wrote about this issue.
And Lightwave users,
By the same error occurs in the results of the test also Octane Main program.
If this is the only problem I had questions quickly tried to look the other way.
Thank you for getting answers to my questions.
