3dsmax 2014 & Camera matching probs
justix
Hi, I need to render using the perspective match tools and I noticed that once I convert the free camera from max to Octane camera I loose the coords and so the perspecive align..I have 2 scripts that I'm using as shortcuts and both on converting the camera fail to retain the exacts camera settings from the perspective match tools ion max..or should I stick to the 3ds camera?
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
tompython
I have the same problem /3ds max 2016, octane render 3/.
Hi guys, how to fix this?
oguzbir
Once you make the perspective match on perspective view or free camera
make sure that the camera is not un-uniformly scaled. By selecting matched the camera and right click on the scale button.
If it's something like x 100.00 y 99.23 z 101.00 the problem is that. Sometimes perspective match scales the max camera to fit the scene.
To overcome this problem try to make the camera match with XY only.
Once you create the max camera. Create an octane camera. And at the same view either perspective or freeCam view press Ctrl - C that should align the octane camera to the view.
My Portfolio
Return to “Autodesk 3Ds Max”
