How to Import Export Render Target???
Moderator: BK
- morphious2013
Been using Poser plugin, so a little lost with DAZ plugin. How do I import a render target, and also, how do I import Redspec SSS from the materials tab???
- morphious2013
Doesn't seem to recognized render targets exported from poser plugin? Also in poser plugin, to apply Redspec Maps you right click on texture node and select import and keep existing maps. I don't see that option in Daz plugin.
Yes - they are different formats. You could however export your Poser scene as OCS or ORBX and input that file into the render settings - that will probably work.Doesn't seem to recognized render targets exported from poser plugin?
You need to refer to the Red-SSS manual for instruction on how to apply the shader.Also in poser plugin, to apply Redspec Maps you right click on texture node and select import and keep existing maps. I don't see that option in Daz plugin.
