Hello,
if you have "special" letters (my case was with "š") in your folder names from which you read an image sequence, it only loads the frame you selected to load and it shows it only when "movie start frame" and "movie end frame" are equal, anything else it outputs as white.
This is easy to avoid by simply cleaner naming, so I am just putting this one out so it could at least get into manual as a warning.
Sandi
Win 10, R17, 2.24.2-R1.2
Image sequence ignoerd
C. RAM Capacity (i.e. 6 GB)
It's fixed on a newer build.
Great, thanks.
