Stereoscopy (side by side)
ThetaGraphics
Currently stereo images in side by side mode render in the opposite positioning from cross-eye viewing and .jps saving. Which means, instead of a quick cross-eye check, I have to save or copy every render to Photoshop and manually switch the images before I can take an accurate look at what I'm rendering. I realize that there are probably programs that use the style of side by side that it renders in, but would it be possible to add a reverse stereo mode, or even allowing a negative value to eye distance should work too?
OctaneRender - DAZ Plugin
Win 10 64-bit | Intel 17-5930K 3.5GHz| RTX 3090 and GTX 1080 | 64GB RAM
This would need to be done in the Octane API rather than the Poser plugin. May I suggest you submit this as a feature request the Octane Standalone alpha 4 release thread where the Otoy devs will see it.
ThetaGraphics
Okay, will do.
ThetaGraphics
...And I appear to have been completely ignored.
~sigh~
Hopefully they'll get around to it someday. :|
Return to “Poser”
