RElease 2.16 for 3dsmax-Highlight compression problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
maxpardo
Hi everyone
I have a problem when using linear mode as Jim explained, setting Max in 2.2.
If I activate the tone mapping from the camera menu in the rendering settings, the highlight compression works ok but the alpha channel is not saved!!!
this is strange
If I uncheck the tone mapping, of course highlight compression doesn't work but the alpha is saved correctly
Anyone with the same problem. Maybe Jim can help me out
thank you
Goldisart
you have to work in gamma 1.0 3dmax
maxpardo
Thank you Goldis!
it works fine in gamma 1
Return to “Bug Reports”
