OCTANE ERROR / TOO MANY VERTICES
magierski
Hi
is there a kind of solution how to solve the problem ?
I got 3x GTX 970 and modo plugin
My scene has couple of milions poligons and couple of textures... octane can not load the scene.
Here you can see my setup in modo and octane error - http://cl.ly/2z3o0w181J1H
thanks for your support !
joshkitney
I've had that same problem too. I just added another zero or two to the end of my maximum vertices.
Is the scene really stupidly big/detailed?
I see you are using V2.24.2, try the new Octane V3 beta. You will need to use 901 though.
i7 5960X Haswell-E 8-Core OC 4.2GHz // 2x GTX 980 Ti Superclocked+, 1 GTX 670 // 64GB's // Windows 10
There is a 19 million TRIANGLE limit in Octane 2. This limit has been lifted in Octane 3 alpha 3 - so try the latest TEST release of the Modo plugin.
Return to “Foundry Modo”
