Instant crash of Cinema or black texture. Just opened mountain scene from content browser. Is c4d layered shader not supported anymore?
UPD...
Ok.layer shader started to work.
c4d fallof node causing instant crash of c4d
doesn't matter if material active or not.
If i have empty scene and material with c4d "falloff map " in it. Cinema will crash when Octane converting c4d materials.
Open scene, open live viewer and hit render...
Layer shader and falloff map
C. RAM Capacity (i.e. 6 GB)
- Attachments
- falloff.rar
- (99.36 KiB) Downloaded 261 times
It's a bit random and can work if you are lucky. Disable multi-processing for C4D shaders and try again. I don't accept this is as a bug, there is some issues about multi-processing and C4D shaders. And i think there is no way.
Octane Settings->C4D shaders->Cpu cores=1caldreemn wrote:Where is this setting, ""Disable multi-processing"?
Searched for it in the Octane Settings and could not locate it.
- caldreemn
- Contact:
Thanks, aoktar!!!aoktar wrote:Octane Settings->C4D shaders->Cpu cores=1caldreemn wrote:Where is this setting, ""Disable multi-processing"?
