Can you alembic export animated hair guides with the octane plugin for Lightwave? Can you export animated 2 point polychains acting as hair guides in an alembic file? Can you export curves in an alembic file?
Can you directly import openVDB smoke sims from Houdini in Lightwave with the Octane plugin? Is there an OpenVDB node in the Lightwave plugin?
Thanks in advance for reading this post.
Can you alembic export animated 2 point polychains?
I think that currently you can't export hair guides or two point polygons to an alembic file using the LW plugin.
You can use an OpenVDB file from Houdini inside LightWave without problems, using the already available OpenVDB loaded inside the Octane_volumetrics custom object tool.
