Rhino plug-in isn't working
jbmn
I have a Rhino 5 SR 12, and I have downloaded the last Octane 2_23 for Rhino 64bit.
I installed everything as usual, but once I open Rhino and I want to add the OctaneRender-tab, nothing happens...
Strangely the Materials-tab occurs without problems, and when I check in Tools>Options>Plug-in I see my OctaneRenderForRhino installed and anabled.
Has anyone an idea what the probleme is due to?
Thanks in advance for your help.
Bests, Mike
Hi. I am not sure which version you have installed. The latest stable version is 2.24.2.57, so unsure what your reference to 2.23 is. The latest version is available from viewtopic.php?f=41&t=40422.
Pls also note:
The installer is now a Rhino RHI package (so drag into Rhino to install). IMPORTANT: YOU MUST UNINSTALL ANY PREVIOUS VERSION OF THE PLUGIN YOU INSTALLED VIA THE PREVIOUS INSTALLER EXE.
Return to “Rhinoceros 3D”
