hello
I'm sorry for my bad English I go through the translation french to english of google!
I often work on visual 7230 X 5428 pixel with C4D.
you can see my work http://www.krop.com/Manfredi
Octane can go resolutions like this 7230 X 5428 pixel ?
what hardware configuration you can advise me?
Thank you in advance
7230 X 5428 pixel
the licensed version of Octane can go up to 8192x8192. You of course must have enough VRAM to handle that (my GTX295 is not capable of it for instance).
Regards
Regards
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
Well, the answer is yes and no: Theoretically you could make the image of size 8096x8096 pixels. But you will run out of memory before you get to those sizes. For your resolution the filmbuffer alone (incl. the display buffer) would be ~780MB. Then there is geometry, textures and other stuff that has to fit on the graphics card, too. -> For those resolutions a graphics card with at least 2GB memory is highly recommended.hdri3d wrote:hello
you can see my work http://www.krop.com / Manfredi
But there is another option: I'm currently working on the next version of the C4D exporter plugin (should be available next week). The latest version of Octane supports now lens shift (or "film offset" in C4D-speak). Together with the tiled camera expression you can then render the image in tiles, which will reduces the needed film buffer size accordingly.
I hope, this helps. Cheers,
Marcus
Yes. (See here for more info: http://www.refractivesoftware.com/forum ... f=5&t=2754)hdri3d wrote: Octane can go resolutions like this 7230 X 5428 pixel ?
I have also heard that a large scene could be rendered out in pieces by using the new lens shift feature, but I haven't tried it. (See here for more info: http://www.refractivesoftware.com/forum ... 60&start=0)
You will need a top of the line, very fast video card with lots of memory. Something like the upcoming NVIDIA GTX 580 3GB (see here: http://www.refractivesoftware.com/forum ... =25&t=5060)hdri3d wrote: what hardware configuration you can advise me?
thank you for your reply
I will buy this setup you think is good
http://www.materiel.net/ordinateur/mate ... 62707.html
Thx Marcus
very good news
http://www.maxoncomputer.com/tutorial_d ... rialID=316
this script it's very good for restitching image
http://vrayc4d.com/files/223_tile-camer ... r-all.html
camera-auto-restitcher
very good news
This expression is very old. You will find the current version in the Content Browser under Presets -> CINEMA 4D -> Expressions -> Tiles Camera. I made it, when I was still working at MAXONhdri3d wrote:Thx Marcus
very good news
BUT, all these expressions do NOT stitch the images together. You have to do it yourself. It should take you less than a minute for a 2x2 tile setup. The task they actually do, is recalculating the field of view of the camera and setting the film offset for each frame of the animation.
Marcus
you is the expression creatre woooaaaaa tiled camera!
I'm really pleased that octane C4D render and will go together perfectly thanks to your work
genial
I'll buy the license
genial
