License / Licensing for Octane Render 3
Notiusweb
Sorry if this is covered elsewhere. Just want to ask how the upgrade process will work.
Lets say I have standalone and 2 plugins @version 2.
1) Is upgrade to V3 standalone done by removing license to V2 and replacing with 3, or does an upgrade to license allow you to then use v2 and v3 (as is case with beta phase now)
2) is each plugin enabled for v3 by upgrading the standalone alone, or are they separate, in that you buy an upgrade for each plugin individually
3) follow up to # 2, if you upgrade plugin to v3, can you still use v2 (as is case in the beta phase now)
Thanks and regards!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
in general, when you upgrade an Octane licence, you are able to use all the latest versions and below, so, if you have a v2 licence, you can use octane v1.2 and the same will be for v3, you will always able able to go back to a previous version ;)
On the other side, if you will not upgrade to v3 when will be possible, all the beta and alpha v3 version will stop to work and you will only able to work with v2 and below.
The same is applied to the plugin, but since we are not so close to the final v3 realize, currently there is not yet an official statement about plugin costs.
We will inform you as soon as possible ;)
Notiusweb
Grazie mille. So che gli sviluppatori di plugin stanno lavorando molto duramente per rendere tutto giusto per tutti.
Plugs: Enterprise
Grazie anche a te per il supporto che dai alla comunità di OctaneRender :)
