problems
angelblame
Nice, but...i can't import .obj files for some reasons. I had a blue screen too, "BAD_POOL_HEADER". I will try the previous version to see if it work correctly :)
Win7 64bits | 2 x GTX480 | Core i7 Quad 2.83ghz | 12GB | 2 Screens (1 cintiq)
abstrax
angelblame wrote:Nice, but...i can't import .obj files for some reasons. I had a blue screen too, "BAD_POOL_HEADER". I will try the previous version to see if it work correctly :)
It's probably the OBJ export settings. Which application are you using and which OBJ export settings? If an export plugin exists for that application, please use that one instead of the normal OBJ export.
Marcus
angelblame
Ok you're right, it's the 3dsmax exporter who wasn't set correctly, thank you !
