Object Motion Blur
Refracty
is there way to render the motion blur of objects directly in Octane?
Refracty
face
No way...
face
http://vimeo.com/user2509578
Jaberwocky
not sure if this might work.I have not tried it personally.Put 6 to 8 copies of your model slightly offset in the x/y/z axis.Render up with 1 at full opacity and the rest at 5% opacity.May be worth a shot as a workaround. ;)
Refracty
@Jaberwocky
Thanks for the workaround. Maybe I will just export motion vectors and add the MB in post. But it would be a great feature in Octane.
@face
Is there a technical reason why it is not possible? I guess it is because the way the exporter handles the geometry but it is possible to create camera motion blur so there must be a way.
Cheers
Refracty
abstrax
Refracty wrote:@Jaberwocky
@face
Cheers
Refracty
Nope there is no way: Octane doesn't support object motion blur yet. And there is no way to communicate object motion blur to Octane. The camera data - including motion blur - is exported via command line and therefor isn't restricted by limitations of the OBJ format.
Marcus
Refracty
Thanks Abstrax,
maybe something for version 2.0...
Cheers
Refracty
abstrax
Don't worry, I also would like to see object motion blur and later full motion blur in Octane, because motion blur does for animations what depth of field does for stills :) We just have to get a few things sorted before that.
Marcus
Return to “Autodesk Maya”
