Rendering flashes on and off and I can't stop it
cosmasad
I'm using the Rhino plugin with settings set for ambient occlusion. I hit Open Viewport and the rendering starts. A few seconds later it turns off (disappears from the screen) then comes back on, then off, then on... I try to stop the rendering but can't.
I end up having to force Rhino down with Task Manager.
I have a medium size file (100 mb) running on a Boxx laptop with 16gb of ram, NVIDIA Quadro K3100 M graphics card.
Any thoughts?
Thank you.
formatio
At first It looks to me like a locked right mouse button :) but it might be something else.
cosmasad
No... I don't think so.
Could it be a setting in the Octane options?
On the Devices tab I have the Render Priority set to Low.
In the Octane options, I have the viewport refresh rate set at 200 ms
Max number of polygons at 10,000,000.
Hmmm....
formatio
hmm - I have the same settings and it's ok.
Have you used it before (octane in rhino) and it worked normally ?
cosmasad
This happens one out of approximately five times. The rest of the time it works beautifully.
formatio
1/5 rhino launch or octanerendervievport open ?
cosmasad
Octane render viewport open.
I switched priority to high. I wonder if that will make a difference.
In each case where the problem happened there were no other programs open.
formatio
Try opening it with this command and see if it start to close and open again:
_OctaneOpenViewport
Also, does this happen on particular scene/file ?
cosmasad
It has only happened with the only scene I've been working with the past couple of days.
Thanks for the tip about _OctaneOpenViewport. I'll try it.
Does it only happen with the Ambient Occlusion pass - or other passes too? Which version of the plugin are you using? Are you able to send me the scene pls?
Return to “Rhinoceros 3D”
