Test 5.2 / Test 6 - The Time Limit setting is being ignored.
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
zoppo
I reported this here, but that was obviously the wrong place: viewtopic.php?f=30&t=51445&start=10
If you set the rendering to animation the time limit setting is being ignored.
After reaching the time limit this message appears but the rendering goes on until it reaches the Max samples set.
In my scene the Time Limit is set to 30 seconds. If you set the Max. Samples to something that renders on your rig for e.g. 40 seconds Cinema will render 30 seconds, then show the "RenderComplete" message but go on for another 10 seconds until it reaches the max. samples..
Then the rendering jumps to the next frame.
Animation_Bug.zip
(81.66 KiB) Downloaded 213 times
C4D 2025 | Win10
It's fixed for next release.
Return to “Bug Reports”
