Changes in 3.0.0.1
- Fixed saving corrupt scene files by changing the render pass setting ids to be Carrara conformant. Note that any scenes saved with version 3.0.0.0 of the plugin are corrupt and cannot be recovered. Sorry for any inconvenience.
- Linked against Octane SDK 3.0 alpha 2
- Added new 'level' option to displacement shader.
- Added new medium option to Octane Environment effect.
- Updated Render Target Settings for the 3.0 SDK.
- Added support for the new Render Passes including new Render Pass save options.
- Added option to save Deep Image EXR files.
- Added support for Cloud Volumes (see notes below.)
Carrara has volumetric clouds that can be rendered in Octane 3.0. I cannot gain direct access to the volumetric data held within Carrara but I can resample the volume. The default resample size is 100x100x100 but you can change this using the Octane Cloud effect. Rendering clouds in Octane is disabled by default so you need to visit each cloud instance and select Enable in the Octane Cloud effect. You can also assign an Octane Medium shader to a cloud instance. This will allow you to change the Absorption, Scattering, and Emission of the rendered cloud. This is done through the standard Carrara shader mechanism. The Carrara native renderer does not use shaders for Volumetric Clouds but you can assign one anyway and Octane will use it if you make it an Octane Medium shader.
Note that only the 'new' Carrara volumetric clouds are supported. The 'old' volumetric clouds, clouds, fire, fountain, and fog do not expose any volumetric data so they are not supported. I will be adding support for OpenVDB files shortly.
Also, please let me know if you are interested in the Baking Camera or Cloud Rendering (using OTOY's OCS cloud rendering service).
As usual, please let me know if you find any other issues.
ATTENTION: This version is based on Octane 3.0. That means you need to update your NVIDIA graphics drivers.
Happy Rendering...
Download Links:
OctaneRender for Carrara (64-bit) 3.0.0.1
