now that skatter is out i would like to test it with some proxy objects.
for this i have tried to use the tree 056, from evermotion Archmodels vol. 01.
http://www.evermotion.org/shop/show_pro ... 52-c4d/845
i imported the obj file into the standalone version - adjusted the textures, and it looked fine.
i then saved it as an .ocs file, and added this file via right-click > octane proxy > from .ocs / . orbx / .obj - but nothing happens - the objects stays the same.
when i select the original .obj file it seems to work fine, but with no materials and a wrong scale.
I use plugin version 0.15.2 and standalone version 2.24.2 - could that be the problem?
thanks
Jorgensen
