Texture Animated for DAZ Studio 4.8 (64 bits). Works?
Moderator: BK
Veneris
I need to know before buying if the animated textures are supported by the plugin.
Which of these two works for DAZ Studio 4.8 (64-bit)? And work with Octane render for DAZ Studio.
Animated Textures Script for DAZ Studio
http://www.daz3d.com/animated-textures- ... daz-studio
Animated Textures Plug In for DAZ Studio
DraagonStorm said:
Animated Textures Script for DAZ Studio will work in Daz Studio 4.8.. I can't tell you about Octane render as I don't know how that works with Daz Studio.
Someone already succeeded in Animated Textures with any of the 2 products that can be created in DAZ Studio and work with the plungin OC for DAZ Studio?
What can you tell me Face_Off, works with that DraagonStorm said?
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
Spectralis
I can't see how the plugin could update the texture with each frame? One solution is to render the object/surface that will use the animated texture as an alpha and then composite this with the animated texture. This won't be affected by the scene lighting though.
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
Yes, I can't see how the texturemap would be updated. If you want to use animated texturemaps - export to ORBX, load into Octane Standalone, and then edit the Image node there to setup the animated texturemaps (using Octane 3).
At some point I will look at implementing animated texturemaps - after all the Octane 3 work has finished.
wendyluvscatz
I read on the DAZ forum it is sadly a limitation of DAZ studio apparently that all the animated texture plugins need a script, OrDS would need to access this script I suppose too, things like Carrara and Poser with inbuilt animation of textures would not have these issues.
Matanim by Casual will not work with iray AFAIK either
Win 10 64-bit CPU Ryzen 3 3600g 32GB RAM graphics RTX2080Ti
Return to “DAZ Studio”
