export AO layer / HDRI backround problem
bertritude73
Hi guys,
I try to export an AO layer using pass in octane render with c4d.
I've an oject + a plane + an hdri environment.
problem is even if i active "alpha layer" in direc tlignhting setings, my AO pass shows a black area (it's the sky of hdri map) and it's not translucent as i want.
It work in octane live viewver but not in export.
do you have an idea plase ?
thks
Bertrand
yes, this is how it works. What do you mean by translucent background?
It's not possible for you to add a white background in post?
Or a big white sphere (big enough to contain the project) only for the ao pass?
bertritude73
thanks for your help,
I just want to have a AO pass alone with a no color translucent (alpha layer) in the sky part.
previously I made a standart render + layer mask.
I want to compile the 3 passes + an image sequence in after effects.
actually there are no issues if you render the ao channel alone, but there are some issues if you do a multipass render, unless you save the final result in PSD format.
please try with this simple scene, there is a Beaty pass + AO pass with alpha channel:
AOAlpha.c4d.zip
(60.21 KiB) Downloaded 312 times
bertritude73
ok, I'll try your test project asap.
i exported in one batch stadard image+ layer mask and in a second way the AO pass (after activate my plane visibility to have the shadows on the plane)
when I export the AO pass with HDRI environment tag even with alpha layer option, the result ihave is good for the plane and the shadows but the sky over the plane is black.
I want the sky translucent.
bertritude73
thanks for your help, it worked with save as PSD file. I've a layer with the alpha :-)
Bertrand
