OctaneRender™ for Blender 2.24.2 - 9.8 OSX [OBSOLETE]
Locked
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Added "Output" section to node editor menu in textures mode.
  • Fixed the LiveDB crash bug (caused by image textures having no filename set in Octane Live database in some materials).
  • Removed the "Tonemapped HDR" setting because there were no use for it (Blender image editor has linear colors input), it just misled some users.
  • Fixed a memory leak: if you had a lot of global meshes in scene, animation of a long sequences ate the memory. (Thanks simdal).
  • Fixed a bug: a modified image textures file re-uploading to the server failed.
  • Fixed a bug: "global" meshes were present in first frame only during "Camera only" or "Movable proxies" animation rendering.
  • Minor fixes and improvements...
Installation:
DOWNLOAD
Blender Octane Edition - v9.8 OSX (82.5MB autoinstaller file)
DEMO is available..
Blender Octane Edition DEMO - v9.8 OSX (81.7MB autoinstaller file)
viewtopic.php?f=24&t=50498
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
Next version HERE.
Locked
