OctaneRender™ for Blender 2.24.2 - 9.8 Linux [OBSOLETE]
Locked
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Added "Output" section to node editor menu in textures mode.
  • Fixed the LiveDB crash bug (caused by image textures having no filename set in Octane Live database in some materials).
  • Removed the "Tonemapped HDR" setting because there were no use for it (Blender image editor has linear colors input), it just misled some users.
  • Fixed a memory leak: if you had a lot of global meshes in scene, animation of a long sequences ate the memory. (Thanks simdal).
  • Fixed a bug: a modified image textures file re-uploading to the server failed.
  • Fixed a bug: "global" meshes were present in first frame only during "Camera only" or "Movable proxies" animation rendering.
  • Minor fixes and improvements...
Installation:
- If you need to run the OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.8 Linux (101.0MB autoinstaller file)
DEMO is available..
Blender Octane Edition DEMO - v9.8 Linux (100MB autoinstaller file)
viewtopic.php?f=24&t=50498
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
grimm
Thanks Jimstar for the fixes. This version seems faster, very cool! :D
Jason
afecelis
Indeed, thanks a lot JS! :D
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
Affenmann
Hi Jim,
I'm on manjaro arch here. Octaneblender needs some libs that are not in my system library path. I copied the first missing libs from other apps (libcrypto from steam install etc..). Octaneblender is ok with it except for libpng12.
Libpng12 is available as 32bit package only here on manjaro arch and installed.
And the /lib/x86_64-linux-gnu/ folder is missing completely :/
Kind regards
Mikola
grimm
ORBX output appears to be broken in this version, I get the following error:
Octane: ERROR downloading scene file from server. Description: No such file or directory
Saved: /data/projects/test/fog-test2.orbx0001.png
 Time: 00:00.72 (Saving: 00:00.02)
If I don't specify a file name in the output then it doesn't error, but all I get is the blank image, no ORBX file.
Saved: /data/projects/test/0001.png
 Time: 00:00.76 (Saving: 00:00.02)
The server doesn't error and just reports the following for both tests:
result is 2, so result is success.
Same for the alembic file output as well, no file is written.
grimm
When using an image for displacement, selecting the reverse button doesn't reverse the image texture. I had to reverse the image in Krita before I could get the texture to come out correctly.
Jason
grimm
Another possible issue, when you export an obj file from Blender (as ORBX doesn't appear to work), the mtl file is not created correctly. The textures get written to the file as glossy with no color, even when they were defined as two diffuse with color textures. I have also noticed that when you have a normal map it always gets put in the mtl file as a bump map. Thanks,
Jason
Did some more research and it might be an issue with Blender not being able to export nodes in a way that will work with mtl?
Next version HERE.
Locked
