My octane won't render, I know it has to do with the scene as it works when i test with one cube.
Hopefully someone knows.... I have out-of-core textures on set to 12gb ram
Started logging on 02.12.15 22:16:04
OctaneRender 2.24.1 (2240001)
Scene created in plugin version -1
Tried to access null item
FRAME 0 fps:24 movable:0 camMb:0 objMb:0
docFrame:0 edRender:0 curFrame:0 From:-1 To:1 rFps:24 docFps:24
Static cnt changed at Frame:-1 cnt:2600
Static cnt changed at Frame:0 cnt:0
Total time:3057 ms. Estimated time:2038 ms.
Calculation completed.... frames:[-1-2]
--------------------------- EXPORT LOG ---------------------------
Tried to access pin via an invalid ID P_DIFFUSE (30)
Tried to access null node pin
Can't connect node 'RGB image' (NT_TEX_IMAGE, 0x7fb21ad2b3e0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node 'tonysculptor Copper' (NT_UNKNOWN, 0x122d6f2d8)
Tried to access pin via an invalid ID P_SPECULAR (222)
Can't connect node 'Mix texture' (NT_TEX_MIX, 0x7fb21ad2ff60) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node 'tonysculptor Copper' (NT_UNKNOWN, 0x122d6f2d8)
Export materials time= 12436.247 ms
Collect objects time= 112.143 ms
Meshes creation time = 9728.6 ms.
Sending to Octane engine time = 0 ms
CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.
-> failed to allocated device memory
Failed to allocate buffer for render passes
CUDA device 0: failed to allocate film buffer for pass "Diffuse direct"
<<< Render Failure >>>
Octane update time = 3385.875 ms.
Octane update time = 0.008 ms.
Total export Time = 228827.553 ms
pFilePath:
pass [Environment] not found...
pass [Emitters] not found...
pass [Diffuse direct] not found...
pass [Diffuse indirect] not found...
pass [Reflection direct] not found...
pass [Reflection indirect] not found...
pass [Refraction] not found...
pass [Subsurface scattering] not found...
