Will version 1.X get an update for Poser 11
Darkseal
Will version 1.X get an update for Poser 11?
I installed the poser 2014 version in the poser 11 and lots of nodes are renamed or not available. Will there be an update for the 1.X users?
What does this mean pls? Can you post a screen of the problem?
Which version of the plugin id you install (ie. what version number)?
Darkseal
Not sure what you mean... I am asking if Ocatane users of version 1, and poser plug in version 1.55 labled for use in poser 2014 will get an update for poser 11.
I cannot really post a "difference" between the 2 programs, as once I activated the plugin in poser version 11 the plugin for poser 2014 stopped working.
Version 1.55, the latest one labeled "stable". Some of the materials are not the same... labled as "rgb color" or "grey scale color" for example while I think other options are missing. Off the top of my head I cannot think of them, and like I said before, I cannot post a screen from 2014 anymore, since activation on Poser 11 will no longer let me bring up the poser 2014 octane plugin window.
I take from your questions, the answer to my question is "no".... else you would have probably answered with a "yes".
What does "stopped working" mean pls? Can you provide the details requested in the top post at viewtopic.php?f=45&t=42585 in order for me to understand what problem you are having. "stopped working" could mean anything.
There are some cosmetic label name changes. This should not change the actual functioning of the plugin. It should still run as before.
In theory, the version 1.x should run under Poser 11. However I have not tested myself. There are details on the plugin specifics for Poser 11 at https://docs.otoy.com/Poser/?page_id=423
Darkseal
It means once I activated the plugin for poser 11, poser 2014 stopped working. This has nothing to do with my initial question, but... are you telling me I can have it active on multiple versions of poser at the same time? If yes, please let me know here and I will post to the link provided.
This might answer my question. But I cannot give you any more info on what I thought was missing unless I deactivate on one version of poser, reactivate the other etc... which I know would only take 5 minutes, but ...... UGH. :roll:
If both Poser 2014 and Poser 11 are on the same PC - then yes, you can have them both active at the same time.
Return to “Poser”
