OctaneRender™ for Blender 2.24.2 - 9.7 Linux [OBSOLETE]
Locked
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Merged with most recent Blender 2.76b version.
  • Fixed the bug: internal motion blur render kept failing if the blurred object existed not in all frames participating in blur calculation.
  • Minor fixes and improvements...
Installation:
- If you need to run the OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.7 Linux (101.0MB autoinstaller file)
DEMO is available..
Blender Octane Edition DEMO - v9.7 Linux (100MB autoinstaller file)
viewtopic.php?f=24&t=50498
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
grimm
Hi Jimstar,
I found an issue when working with an HDRI. If you accidentally delete the output node you can't get it back, unless you delete the texture and start a new one. I tried searching for it in the add menu but it didn't show up in the search list. It would be nice to have the output nodes listed in the add menu.
Jason
Next version HERE.
Locked
