Need help with a rigged character
hilby
Hello, we recently bought a rigged character from turbosquid for maya and we can make everything a moveable proxy, apart from the head. When we do make the head a moveable proxy we get a mesh export error and the renderer stops which I can only assume is due to blendshapes? we have used a rigged character with blendshapes before in 3dsMax with octane and it rendered with no problems which is annoying :( Also as you can see when we render the character, the smooth mesh reverts to a low poly one? when we disable the smooth properties on the meshes and add them ourselves octane renders them properly, pretty strange :? We'd really appreciate any help
Here is the log from octane.
// Octane: starting render, frame 8...
// ****************************** THIN LENS CAMERA *********************************
// Name: perspShape
// Orthographic: 0
// Film width: 35.999928, Focal length: 65, calculated FOV: 30.957218
// Aperture: 1
// Aperture edge: 1
// Distortion: 0
// Auto-focus: 1
// Focal depth: 100
// Persp. correction: 0
// Stereo mode: 1
// Stereo output: 0
// Stereo distance: 0.065
// Near clip depth: 0.01
// Pixel aspect ratio: 1
// Aperture aspect ratio: 1
// Camera: X: -74.69947, Y: 129.143894, Z: 345.797776
// Target: X: -3.567413, Y: 46.470221, Z: -6.977917
// Up: X: 0.0442548, Y: 0.974613, Z: -0.219479
// IMAGER:
// Exposure: 1
// Highlight compression: 0
// Gamma: 1
// Response: 105
// Vignetting: 0.3
// Saturation: 1
// Hot pixel removal: 1
// Premultiplied alpha: 0
// Min display samples: 1
// Dithering: 0
// White saturation: 0
// POSTPROCESSOR:
// Enabled: 0
// Bloom power: 1
// Glare power: 0.1
// Glare ray count: 3
// Glare angle: 15
// Glare blur: 0
// Spectral intensity: 0
// Spectral shift: 2
// 0:00 Octane kernel set: Direct Lighting
// Octane: Scene scale factor: 1
// 0:00 Device "1: GeForce GTX TITAN X (compute model 5.2)" is DISABLED
// Warning: Octane: No CUDA devices choosen to render on. Rendering on the first one: GeForce GTX TITAN X (compute model 5.2) //
// 0:00 Octane engine: creating meshes...
// 0:00 Gathering Mesh objects data...
// Octane: Object "neckShapeOrig" is not visible, skipping...
// Octane: Object "base|girlFace|girlFaceShapeOrig" is not visible, skipping...
// Octane: Object "backup|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "backup|lashLIn|lashLInShapeOrig" is not visible, skipping...
// Octane: Object "backup|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "backup|lashRIn|lashRInShapeOrig" is not visible, skipping...
// Octane: Object "backup|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "backup|girlFace|girlFaceShapeOrig" is not visible, skipping...
// Octane: Object "backup|browL|browLShape" is not visible, skipping...
// Octane: Object "backup|browL|browLShapeOrig" is not visible, skipping...
// Octane: Object "backup|browR|browRShape" is not visible, skipping...
// Octane: Object "backup|browR|browRShapeOrig" is not visible, skipping...
// Octane: Object "browSad|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "browSad|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "browSad|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "browSad|browL|browLShape" is not visible, skipping...
// Octane: Object "browSad|browR|browRShape" is not visible, skipping...
// Octane: Object "browDownR|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "browDownR|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "browDownR|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "browDownR|browL|browLShape" is not visible, skipping...
// Octane: Object "browDownR|browR|browRShape" is not visible, skipping...
// Octane: Object "browDownL|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "browDownL|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "browDownL|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "browDownL|browL|browLShape" is not visible, skipping...
// Octane: Object "browDownL|browR|browRShape" is not visible, skipping...
// Octane: Object "browUpR|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "browUpR|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "browUpR|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "browUpR|browL|browLShape" is not visible, skipping...
// Octane: Object "browUpR|browR|browRShape" is not visible, skipping...
// Octane: Object "browUpL|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "browUpL|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "browUpL|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "browUpL|browL|browLShape" is not visible, skipping...
// Octane: Object "browUpL|browR|browRShape" is not visible, skipping...
// Octane: Object "eyeLaughR|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "eyeLaughR|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "eyeLaughR|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "eyeLaughR|browL|browLShape" is not visible, skipping...
// Octane: Object "eyeLaughR|browR|browRShape" is not visible, skipping...
// Octane: Object "eyeLaughL|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "eyeLaughL|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "eyeLaughL|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "eyeLaughL|browL|browLShape" is not visible, skipping...
// Octane: Object "eyeLaughL|browR|browRShape" is not visible, skipping...
// Octane: Object "eyeClose|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "eyeClose|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "eyeClose|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "eyeClose|browL|browLShape" is not visible, skipping...
// Octane: Object "eyeClose|browR|browRShape" is not visible, skipping...
// Octane: Object "b|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "b|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "b|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "b|browL|browLShape" is not visible, skipping...
// Octane: Object "b|browR|browRShape" is not visible, skipping...
// Octane: Object "v|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "v|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "v|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "v|browL|browLShape" is not visible, skipping...
// Octane: Object "v|browR|browRShape" is not visible, skipping...
// Octane: Object "u|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "u|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "u|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "u|browL|browLShape" is not visible, skipping...
// Octane: Object "u|browR|browRShape" is not visible, skipping...
// Octane: Object "i|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "i|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "i|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "i|browL|browLShape" is not visible, skipping...
// Octane: Object "i|browR|browRShape" is not visible, skipping...
// Octane: Object "expressions|e|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "expressions|e|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "expressions|e|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "expressions|e|browL|browLShape" is not visible, skipping...
// Octane: Object "expressions|e|browR|browRShape" is not visible, skipping...
// Octane: Object "O|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "O|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "O|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "O|browL|browLShape" is not visible, skipping...
// Octane: Object "O|browR|browRShape" is not visible, skipping...
// Octane: Object "Ah|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "Ah|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "Ah|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "Ah|browL|browLShape" is not visible, skipping...
// Octane: Object "Ah|browR|browRShape" is not visible, skipping...
// Octane: Object "surprise03|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "surprise03|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "surprise03|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "surprise03|browL|browLShape" is not visible, skipping...
// Octane: Object "surprise03|browR|browRShape" is not visible, skipping...
// Octane: Object "surprise02|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "surprise02|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "surprise02|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "surprise02|browL|browLShape" is not visible, skipping...
// Octane: Object "surprise02|browR|browRShape" is not visible, skipping...
// Octane: Object "surprise01|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "surprise01|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "surprise01|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "surprise01|browL|browLShape" is not visible, skipping...
// Octane: Object "surprise01|browR|browRShape" is not visible, skipping...
// Octane: Object "sad04|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "sad04|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "sad04|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "sad04|browL|browLShape" is not visible, skipping...
// Octane: Object "sad04|browR|browRShape" is not visible, skipping...
// Octane: Object "sad03|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "sad03|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "sad03|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "sad03|browL|browLShape" is not visible, skipping...
// Octane: Object "sad03|browR|browRShape" is not visible, skipping...
// Octane: Object "sad02|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "sad02|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "sad02|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "sad02|browL|browLShape" is not visible, skipping...
// Octane: Object "sad02|browR|browRShape" is not visible, skipping...
// Octane: Object "sad01|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "sad01|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "sad01|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "sad01|browL|browLShape" is not visible, skipping...
// Octane: Object "sad01|browR|browRShape" is not visible, skipping...
// Octane: Object "angry03|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "angry03|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "angry03|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "angry03|browL|browLShape" is not visible, skipping...
// Octane: Object "angry03|browR|browRShape" is not visible, skipping...
// Octane: Object "angry02|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "angry02|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "angry02|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "angry02|browL|browLShape" is not visible, skipping...
// Octane: Object "angry02|browR|browRShape" is not visible, skipping...
// Octane: Object "angry01|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "angry01|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "angry01|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "angry01|browL|browLShape" is not visible, skipping...
// Octane: Object "angry01|browR|browRShape" is not visible, skipping...
// Octane: Object "laugh03|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "laugh03|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "laugh03|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "laugh03|browL|browLShape" is not visible, skipping...
// Octane: Object "laugh03|browR|browRShape" is not visible, skipping...
// Octane: Object "laugh02|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "laugh02|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "laugh02|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "laugh02|browL|browLShape" is not visible, skipping...
// Octane: Object "laugh02|browR|browRShape" is not visible, skipping...
// Octane: Object "laugh01|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "laugh01|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "laugh01|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "laugh01|browL|browLShape" is not visible, skipping...
// Octane: Object "laugh01|browR|browRShape" is not visible, skipping...
// Octane: Object "smile04|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "smile04|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "smile04|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "smile04|browL|browLShape" is not visible, skipping...
// Octane: Object "smile04|browR|browRShape" is not visible, skipping...
// Octane: Object "smile03|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "smile03|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "smile03|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "smile03|browL|browLShape" is not visible, skipping...
// Octane: Object "smile03|browR|browRShape" is not visible, skipping...
// Octane: Object "smile02|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "smile02|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "smile02|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "smile02|browL|browLShape" is not visible, skipping...
// Octane: Object "smile02|browR|browRShape" is not visible, skipping...
// Octane: Object "smile01|lashLIn|lashLInShape" is not visible, skipping...
// Octane: Object "smile01|lashRIn|lashRInShape" is not visible, skipping...
// Octane: Object "smile01|girlFace|girlFaceShape" is not visible, skipping...
// Octane: Object "smile01|browL|browLShape" is not visible, skipping...
// Octane: Object "smile01|browR|browRShape" is not visible, skipping...
// Octane: Object "legRShapeOrig" is not visible, skipping...
// Octane: Object "legLShapeOrig" is not visible, skipping...
// Octane: Object "tieRShapeOrig" is not visible, skipping...
// Octane: Object "tieLShapeOrig" is not visible, skipping...
// Octane: Object "buttonRShapeOrig" is not visible, skipping...
// Octane: Object "buttonLShapeOrig" is not visible, skipping...
// Octane: Object "clothShapeOrig" is not visible, skipping...
// Octane: Object "handLShapeOrig" is not visible, skipping...
// Octane: Object "handRShapeOrig" is not visible, skipping...
// Octane: Object "arm_R|armShapeOrig" is not visible, skipping...
// Octane: Object "arm_L|armShapeOrig" is not visible, skipping...
// Octane: Object "skirtShapeOrig" is not visible, skipping...
// Octane: Object "girlPantShapeOrig" is not visible, skipping...
// Octane: Object "shoeRShapeOrig" is not visible, skipping...
// Octane: Object "tieShoeRShapeOrig" is not visible, skipping...
// Octane: Object "shoeLShapeOrig" is not visible, skipping...
// Octane: Object "tieShoeLShapeOrig" is not visible, skipping...
// Octane: Object "h|lashLIn|lashLInShapeOrig" is not visible, skipping...
// Octane: Object "h|lashRIn|lashRInShapeOrig" is not visible, skipping...
// Octane: Object "h|browL|browLShapeOrig" is not visible, skipping...
// Octane: Object "h|browR|browRShapeOrig" is not visible, skipping...
// 0:00 Setting Mesh data of mesh: girlFaceShape
// ****************************** MESH DATA ******************************
// Number of vertices: 1746
// Number of normals: 1746
// Number of UVs: 1766
// Number of polygons: 1698
// Number of vertex indices: 6792
// Number of normal indices: 6792
// Number of UV indices: 6792
// Number of material indices: 1698
// 0:00 ...done setting Mesh data in 0:00
// 0:00 Voxelizing...
// 0:00 ...voxelized in 0:00
// Error: Octane: duplicated name of transform "girlFace", change it to unique //
// Error: Octane: Error mesh export. Octane render stopped. //
Asus X99 motherboard, i7-5930K CPU, Samsung SSD 850 PRO, 32 GB DDR4 Quad Channel RAM, Dual display 2x Nvidia Geforce GTX TITAN X 12 GB , Windows 8.1 Pro, 3DS Max 2016 x64
Do you see the last error about duplicated transform name? If you are sure there are no such girl face transforms with duplicated name in the scene - could you give me the scene to I can reproduce this?..
hilby
Hi, thanks for the quick reply :D here is the rigged scene, thank you very much, we tried to change the name but then the blendshapes stopped responding :(
girlSet.rar
(1.82 MiB) Downloaded 329 times
solomon
hilby wrote:Hi, thanks for the quick reply :D here is the rigged scene, thank you very much, we tried to change the name but then the blendshapes stopped responding :(
Hi hilby, were you able to figure out the solution to this problem? I am getting the same error when I assign moveable proxy to my character mesh attachments like hair that is parented to a skeleton
Solomon W. Jagwe
Wenneker
Hi Hilby,
Some points to help you out.
1: The smoothing is controlled by Octane:Level. It's under the ExtraAttributes of the shapenode. Viewport smoothing doesn't work with OctaneMaya.
2: Blendshapes and skinned meshes have to be Reshapable Proxies, otherwise they won't move.
3: Octane is pretty picky when it comes to naming. Try to make shure there are no duplicate names in the project. This goes for both shapenodes and transforms (including groups)
4: Try the attached file it should work. ;) You will have to re-assign your shaders though.
girlSet.rar
(1.83 MiB) Downloaded 308 times
Win 7 x64 | i7-4930 | 64gb | 4x gtx 780Ti 3gb
Return to “Autodesk Maya”
