I must be lacking sleep today! Or the newest build has broken this...
What do I do to rotate the backdrop image correctly? This setup rotates on the wrong axis. Thanks.
Texture Backdrop not Rotating Correctly
I may be on wrong track but if you want to rotate the environment map, use the Heading Rotation and Pitch Rotation in Environment:Texture node, not image's UV3dreamstudios wrote:I must be lacking sleep today! Or the newest build has broken this...
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
- 3dreamstudios
Nope, found it though. It's under HDRI image rotation.atnreg wrote:I may be on wrong track but if you want to rotate the environment map, use the Heading Rotation and Pitch Rotation in Environment:Texture node, not image's UV3dreamstudios wrote:I must be lacking sleep today! Or the newest build has broken this...
Antti
- FrankPooleFloating
Keep in mind that Color Correct node (et al) breaks HDRI rotation ability.
