OctaneRender® for Maya® 2.24.2 - 7.14 Linux [OBSOLETE]
Locked
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Added "Save composite EXR file" setting to "Additional" rollout of Octane settings. If set - the multilayer image file will be saved, if not set - the separate files will be saved for each pass. In the case of subframe motion blur is enabled - always the separate image files will be saved.
  • Added "Enable layers", "Invert layers" and "Active layer ID" parameters to Octane batch render command line. You can use the command line now to batch-render different Octane object layers.
  • Fixed OpenSubDiv sharpness bug: in some cases the setting did not affect the render result.
  • Minor fixes and improvements...
Installation:
DOWNLOAD
OctaneRender for Maya - v7.14 Linux (19.5MB autoinstaller file)
OctaneRender for Maya - v7.14 Linux DEMO (18.6MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
Next version HERE.
Locked
