OctaneRender® for Maya® 2.24.2 - 7.14 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • Added "Save composite EXR file" setting to "Additional" rollout of Octane settings. If set - the multilayer image file will be saved, if not set - the separate files will be saved for each pass. In the case of subframe motion blur is enabled - always the separate image files will be saved.
  • Added "Enable layers", "Invert layers" and "Active layer ID" parameters to Octane batch render command line. You can use the command line now to batch-render different Octane object layers.
  • Fixed OpenSubDiv sharpness bug: in some cases the setting did not affect the render result.
  • Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.24.2 - 7.14 (12.5MB autoinstaller file)
OctaneRender for Maya 2.24.2 - 7.14 Demo (11.6MB autoinstaller file)
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
avajjon
Thank you for the update.
I have been working on a project when I installed 7.13 and after installation, when I batch render the same scene, it takes a lot of time to begin rendering compared to previous versions. it took about 30 min to start rendering the first frame and then it renders at normal speed. I have tested the same scene with this release and the problem still exists.
IPR render with the same settings takes about 10 - 15 seconds to start rendering but batch render is extremely slow compared to IPR.
cheers.
avajjon
Could you give me this scene?
avajjon
I'm testing your scene, and so far I can't get any difference in translation time... Both an IPR session and a batch render finish translation of the first frame in about 18-20 seconds, both in 7.12 and in 7.14.
The rendering itself takes a lot more time, but again - it is the same in 7.12 and in 7.14 (in both IPR and batch), and it is consistent with the complexity of the scene and 2000 max. samples set... Both 7.12 and 7.14 use the same 2.24.2 Octane engine, so no surprise here.
How do you measure exactly the time of translation when you do the batch rendering?
Can
Hi jimStar,
I have to deactivate and activate 3 plugins and octane itself two times at day.
At the activation of maya plugin there is an issue on my both computers (home and office).
While activating I paste the username and password into the fields.
And in the pw field the text isn't hidden,,, you can see the whole pw, instead of "*".
May be a bug or similar?
Can
Autodesk Entertainment Creation Suite Ultimate 2016 & Cinema4D Studio 17
Octane V2 Standalone + Plugins (Maya, Max, C4D)
Windows 10 x64 Pro | 2 x Titan X | i7 4790K | 32GB
Windows 10 x64 Pro | GTX 570M | i7-2670QM | 16GB
avajjon
Hello Jimstar,
I think you have understand the situation, but somehow you couldn't reproduce the same problem. Hardware/software or OS related perhaps ?.
I have recorded a screencast to better explain the issue I am getting with this scene.
Thank you.
ScreenCast_Octane.mp4
Batch Render issue demonstration
(3.21 MiB) Downloaded 10283 times
avajjon
No, you are wrong. I thought about something like this when asked you previously "How do you measure exactly the time of translation when you do the batch rendering?".
Read please the batch rendering message you get (at 2:42): "... Percentage of rendering done ...". Done, not "started". It even states the name of already finished image file written. So, this moment is not the moment when "Batch render started" but the moment when it has already finished the rendering of the first frame and has successfully written it to the disk. Taking into account the complexity of the scene and 2000 max. samples set - this is the total time spent for loading the new "mayabatch" process, translate the scene into Octane engine, render the 2000 samples of the first-frame image, and save this image to the disk. Not the time before rendering "starts".
avajjon
I don't get it.
It has not finished the rendering of the first frame yet it, when the message appeared it says %2 percent completed. But the real issue here it takes 25 minutes to get the first %2 completed for the first frame message, I have obviously cut the video not the watch it is happening for 25min. After the first message appears the render speed is normal, which is about 7-8 minutes per image. Why would scene translation time be so different than the IPR render when every setting is exactly same.
IPR 22 sec
Batch 25min
This is 2% of the whole batch sequence done, not of the first frame.
avajjon
Ahh I didn't know that, I thought it was image percentage feedback like the most other render engines. Yet I am using Octane for 2 years lol.
Anyway, I have tested for one frame batch render to make everything equal.
Render started 04:30 finished 04:56 it took 26 min to render first frame.
IPR rendered the same frame in 26 min.
Everything is illuminated.
Thank you.
Locked
