ORBX or Rhino2Octane ?
parsa021021
Is it possible to export Named Views inside Rhino as ORBX? It's no possible to export any ORBX while in demo mode. That why I'm asking. I'm planning to purchase it. I know I can do this with the SketchUp plugin. I'm using Rhino2Octane script but I wish I could export several cameras. I don't know any Lua either. Is there a way in the Standalone to setAttr of a new camera node from exiting camera attributes you imported from Rhino using Rhino2Octane?
The OctaneRender for Rhino plugin can do this (open the Viewport and export to ORBX). You can also copy the Octane camera from OctaneRender for Rhino into the Windows clipboard and paste it into Octane Standalone. I am unfamiliar with the Rhino2Octane script, but I'm sure it would only export as OCS, not ORBX.
parsa021021
Fascinating. I'm new to Rhino plugin. When I copy camera I only able to past it in rhino's octane. I can't past it in stand alone! Also what is export render target setting as xml and can I use the file in Standalone?
Use the OctaneCopyCameraToClipboard command that was added to the latest TEST release (2.24.2.54) to copy form the plugin to Standalone. https://docs.otoy.com/Rhino/?page_id=711
No - the rendertarget export can only be used by the OctaneRender for Rhino plugin.
You can always export the scene to OCS or ORBX and open in Octane Standalone to access the rendertarget settings.
Return to “Rhinoceros 3D”
