Texture is missing in octane for poser
janedj
Can someone help?
Some texture is missing in octane for poser, It is not all the time it depends on which texture I am using. when I use texture from fabiana material it is always missing?
Thank you
Jane
TRRazor
What texture is missing specifically?
Diffuse, bump, specular?
janedj
When I load a texture from material room from fabiana, there is no texture in octane it is only white , just like plastic! In poser it is okay and it is not missing!
Jane
Hi Jane - I suspect the texturemaps are hidden in the Poser Material node structure. If you view the material in question in the Poser Material room, and click the Simple tab - if the texturemap is not showing in the Diffuse Color - it will not be picked up by the plugin.
TRRazor
Are we talking about character materials or other objects?
Although the same principles apply, fixing the problem might be more or less complicated, hence the question.
Return to “Poser”
