Creating VR Content from Octane-Cinema4D
go2productions
Hi There,
I am planing to create a VR content from Octane-C4D. Which Oculus will be needed best between Gear VR and DK2?
Also where can I find any tutorial links to do that out from Octane-C4D?
I saw some posts showing how-to make it from 3D-MAX. Will it works the same way in C4D?
Thank you so much.
J.
yes sure, you can render any Oculus VR contents with c4d-Octane.
Just create an Octane camera or add an Octane Camera Tag to an existing camera. Then, in the attributes of the tag you can switch the node from Thin-lens camera to Panoramic camera and choose between equirectangular or cube map. Don't forget to set up also the stereo option and to correctly set the size of the render based on the vr format chosen.
Happy GPU-VR rendering ;)
