Catching light part 2
enricocerica
Still catching light, here is the first image of a new serie based on the same scene with some variations. I also equiped new rooms and added several props.
Like the previous serie, there is some postpro to add CA, reduce noise and increase/improve lighting in some regions.
Duno if the bloom is too high in this first image.
http://www.myline.be
joseph
use a soft cloth to remove the stains from the piano :)
joking.... love the stain detail!
Win XP 32bit | Nvidia Quadro FX 1700(display) and GTX 470 | Intel Core2 Quad 2.66 Ghz | 3 GB RAM
enricocerica
Thanks Joseph,
Just added a second image.
radiance
Awesome :)
Did you use a procedural on the piano ?
Radiance
enricocerica
radiance wrote: Did you use a procedural on the piano ?
Radiance
No, I used a spec map, but I should try to use procedural more often.
radiant
very professional render and camera position :D
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
john_petrucci
Hi, Very impressive images, you can illustrate the disposition of lights??
Thank you!
Paolo
Windows 7 64 Bit | 2 X GTX 580 1.5 GB |
enricocerica
I added the kitchen and rendered two new images.
john_petrucci wrote:Hi, Very impressive images, you can illustrate the disposition of lights??
Thank you!
Paolo
Nothing special from lighting point of vue, the 3 first images simply use an hdr map, for the 4rh I used an hdr map and some mesh lights.
