OctaneRender™ for Blender 2.24.2 - 9.6 Win [OBSOLETE]
Locked
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • New 2.24.2 engine.
  • Improved the camera view to support the viewport shift.
  • Minor fixes and improvements...
Blender Octane Edition - 9.6 (2.75) (67.7MB autoinstaller file)
Octane Server - 2.24.2 - 9.6 (10.8MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.23.4 - 9.6 (10.0MB autoinstaller file)
viewtopic.php?f=24&t=50498
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
Marten74
Hello Jim!
I often find my self curious what changes the new engine versions hold, and try to find it in the forums. It´s rather impossible with little aid from the search function. Could you, if it exists, maybe add a link to that information when you post a new engine?
Thanks!
saikafu
Great job , but I still want to know when we can have don't render hair emitter function??
afecelis
Hi JImStar,
Rendered viewport is slow again? :(
EDIT: nevermind, my bad, I was on PMC kernel. In direct lighting it's very fast :D
One last question: On the same machine/hardware, Windows/Linux dual boot, why is realtime performance on Linux so slow compared to Windows' ? Linux driver less efficient?
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
saikafu
Hi there ~~I would like to know , does the ORBX or Alembic not work now????? I always crash while export , any answer ???????????
enricocerica
Do I miss something or there is a problem with the environment texture.
I'm trying to use an hdr map but with no result :roll:
http://www.myline.be
Marten74
Is it possible to animate a texture over a surface? Trying to figure it out with the full transform node and projections, but with no luck...
Cheers!
Marten74
Hello!
I will quickly report an issue I discovered in an ongoing project. I made a simple scene to demonstrate the issue.
When rendering movable proxies with internal motion blur, you can´t animate visibility without Octane Server crashing on the frame just before objects get visible. Now when quickly testing, the crashes are not totally predictable. Some times it is when rendering the animation, some times during regular rendering, and in the test scene always when preview rendering. In my big scene some times preview rendering and regular rendering could work, but animation always crashed the server.
Since this issue occurs often, but not always, I hope it is considered a bug that can be fixed
Server_chrash_animating_visibility_motion_blur.blend
(584.91 KiB) Downloaded 264 times
dafassi
Feature-Request:
Is it possible to make "animated" animation-previews in viewport (textured/material/rendered).
So we could see the animation while scrubbing the timeline or using the L/R arrow keys. Yet the actual frame will only be visible while rendering or switching from viewport "solid" another one.
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
Next version HERE.
Locked
Return to “Blender”
